How to repair connectivity between solid elements and cbeam elements
Hello everyone,
The image of the model that I will use to describe the problem is given below. The model includes solid elements and CBEAM elements.
There was only a line in the imported geometry. I created CBEAM elements using linemesh. Then I defined solid elements using linedrag.
There seems to be no apparent connection problem, and when I check the elements, there is no problem either. However, when I analyze it, I see that the two components are not interconnected. Displacement values are infinitely larger.
How can I overcome this problem? Considering that, geometry consists entirely of line elements.
Thanks.
1 - 1 of
11
Check equivalent nodes between solid mesh & beams?
