How to repair connectivity between solid elements and cbeam elements
Faik Fatih Korkmaz
Faik Fatih Korkmaz Altair Community Member
edited March 2021 in Community Q&A
Hello everyone,
The image of the model that I will use to describe the problem is given below. The model includes solid elements and CBEAM elements.
There was only a line in the imported geometry. I created CBEAM elements using linemesh. Then I defined solid elements using linedrag.
There seems to be no apparent connection problem, and when I check the elements, there is no problem either. However, when I analyze it, I see that the two components are not interconnected. Displacement values are infinitely larger.
How can I overcome this problem? Considering that, geometry consists entirely of line elements.
Thanks.
Best Answer
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited March 2021 Answer ✓
    Check equivalent nodes between solid mesh & beams?
  • Q.Nguyen-Dai
  • Faik Fatih Korkmaz
    edited March 2021
    It is working. Thank you. You saved me a lot of work because I try to add rigid elements after translating nodes near the solid component.
    Solution: Tool > Edges, Mark All, Tolerance = 4, Preview equiv, Equivalence.
