I try to open my inspire cast software but only it will load up and never completely open the app.
Hi Roberto,
Can you share the image of this issues? May be this model quite big, so it takes time to load the model.
Or can you share the model for me to check?
Thanks.
Hi Roberto, Can you share the image of this issues? May be this model quite big, so it takes time to load the model. Or can you share the model for me to check? Thanks.
I am not opening any model only the software.
It doesn´t advance from this window
I am not opening any model only the software. It doesn´t advance from this window
Please check the license file and front text in your machine (may be have special front that Inspire Cast don't support).
Best regards.
Hi Roberto,
Thanks.
