Nothing Happens when I click Optistruct
I am trying to use Optistruct for Topology Optimization.
I imported a geometry in a STEP file, meshed it, gave it material properties, loads & constraints - However when I click to run Optistruct, nothing seems to process, and no screen appears.
I think I am supposed to at least get an .out file to at see the status of my work. When I click 'view .out' - it says 'out file does not exist' on the bottom left corner of the screen
I followed the tutorials from Altair University to get this far.
I have also tried uninstalling and installing the program in case it was an installation error.
Why am I not seeing anything happen when I click Optistruct?
Thank you~
Thank you~
1 - 3 of
31
Hi,
I tried running the same in HyperWorks 2017 Student Edition and it was successfully done. The files are attached for your reference.
Please delete the settings files and try running. The below post shows deleting the settings files:
Hi,
Can you please share the file so that we can review.
