Using connectors in Hypermesh
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello and good afternoon,
I currently have a few problems using connectors in my Hypermesh-Simulation. I am trying to connect different parts of my model together via connectors to simulate the mechanical behaviour of a welded model.
The problem with my connectors is, that they are not transferring the load into other parts of my model. I think I set them up incorrectly. Is there any kind of tutorial on how to apply connectors?
I attached a few pictures using different connectors. You will see that the parts of my model are set up with a distance of 2mm to each other. I tried using no distance first, but I could't not get the connectors to realize. Without a gap between the model parts they were always either yellow or red. Using a litte space between the parts could get the connectors to realize at least.
The only time I could get the applied loads to transfer was by using RBE2-elements and an unexploded model.
Many thanks
Steffen
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited February 2016
    Hi,
    it's better to share your model.
    there are several problems could occur in your model we cannot tell you detail.
    so let us debug it after that we will tell you reason
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    Hi,
    thank you very much. I attached my model to this post.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Steffen,
    Instead of PLOTTEL element type use WELD elements or BAR element type.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    I see some of the parts are not connected.please connect it properly and then run.It model is properly connected with weld or rigid then only it will transfer load.
    See attached screenshot.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    I apologize for being so annoying, but changing the element type to 'weld' brought up another error message:
    *** ERROR # 722 ***
     An invalid rigid element.
     This RBAR is not connected with any structural element.
         RBAR element id = 124520
     independent grid id = 30523
       dependent grid id = 30524
     Note: If this rigid element is also connected with other rigid elements,
     then this error means that there is rigid body mode or mechanism remained
     in this rigid element chain due to lack of connected structural elements.
    Since I'm relatively new in the world of using Hyperworks programs, I'm not sure how to read the occurred problems out of the error messages.
    I noticed that some the nodes are connected to different RBAR-lines, but even after deleting these, the problem remains the same.
    But I guess it would still be an issue even after the first problem is fixed? Or do connectors behave differntly compared to 'normal' RBE-Elements?
  • Rahul Rajan_21763
    I suggest to use RBE2 element and apply 1d checks like dependency and free nodes. As mentioned above connect part properly to avoid rigid body motion.
    Regards
    Rahul R
  • tinh
    Hi Steffen
    You have used SEAM connectors
    please change to using SPOT connectors with elem type is WELD or RBE2/RigidLink/RBE3,...
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Steffen,
    The problem is coming from the type of element you are using to model the welds. In your base model you had PLOT elements which doesn't make sense. Instead use element types which transfers as Tinh and I suggested.
  • tinh
    additional explain,
    using SEAM connectors, weld (rbar) elems will not connect nodes-nodes of 2 comps. so you got error 'rbar is not connect with any structural element'
    enter panel F10>1d =>check free 1d to ensure no error rbar/rbe2... existing
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Oh, god. It is amazing for us. How nice about that.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2017
    is spot weld is applicable only for shell mesh?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    Its possible to create spot weld for solid elements also.
Welcome!
Welcome!
