Altair RISE
Nominate Yourself Now!
How to select elements enclosed by a solid?
User: "Aravind Vissamsetty"
Altair Community Member
Updated by Aravind Vissamsetty
Hello.
I have this large model that is already meshed with surface elements and does not have any geometry associations. My goal was to select elements along strips of a certain width, along the length of the model.
I created a solid body in a CAD program for my required shape (with enough tolerance on both sides) and imported it into HyperMesh. It is now superimposed upon the elements, as I intended it to.
imageMy goal is to select the elements (or even the nodes) enclosed by that solid body. I tried to do that by using the "by Geoms > Solid" option, but I understand the elements/nodes have to be associated to the body for that to work.
How can I associate them to the newly imported body?
1 - 2 of 21
    User: "Jason_Craanen"
    Altair Employee
    Accepted Answer
    Updated by Jason_Craanen
    Hello,
    OP
    Hello,
    Thank you for the reply. I figured the same thing out from some old posts elsewhere, when I understood that I should be trying to associate the nodes to the instead of the elements.
    But this was quite clear and should help anyone who has a similar question in the future.
