for OptiStruct, usually RAM is the more important, as having enough memory would allow you to use in-core mode, wwhich runs faster.
But of coarse a good SSD and a fast CPU helps.
RAM >> larger models require more RAM memory to run efficiently
SSD >> a good SSD will speed-up computations when large data blocks need to be used (this tends to be less important if enough RAM is available)
CPU >> newer CPUs are more efficient. But number of core's are not so heavily important for OptiStruct. You can have a gain, but it also depends on how many licenses you have available and kind of model. Explicit codes tend to take more advantages.
I agree with the above replies, and depending on how old ytour machine is maybe s better to replace it.
If your models are heavy, I would say CPU, RAM and SSD !
