Hi Jackie
You will find attached a memento for PyFlux.
I don't understand you last question : Is there a way to change PyFlux code to Python code ?
Flux use python to create loop, objects, ... but it is not possible to convert Python Flux object to 'pure' python.
You need Flux to create and evaluate the object.
Yann
Hi Jackie
Yann
Thanks for your help Yann!
Also, Is there a way to change PyFlux code to Python code?
