I am using Hypermesh 2021 version. I couldn't determine only positive or negative direction constraint on my model. which tool I should use for that constraint which I describe just +Z direction SPC constraint not -Z direction ?
Personally I have created this behavior in Optistruct by using gap elements or contact. One specific contact with might work very well for this is Fast Contact.
Hello,
https://2022.help.altair.com/2022/hwsolvers/os/topics/solvers/os/contact_os_c.htm#contact_fast_contact_c
