🎉Community Raffle - Win $25
Join and Win
Error in a code while number of nodes is higher
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi,
when I am running my macro if the number of nodes is higher am getting the above error.
Any idea about this.
I used lists and 2 inner for loop for iterating through nodes.
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Please replace {nodes $uniqueList} by 'nodes $uniqueList'
    Altair Employee
    OP
    Hi
    hi tinh,
    Thanks .
    But initially when I running the macro for small model it worked.
    why its not working for big ones.
    User: "tinh"
    Updated by tinh
    Hi,
    Maybe in small one, it does not call that command
    Altair Employee
    OP
    Hi,
    hi,
    Thanks tinh.
    the command gets the call.
    As per iterations I done and some studies came across I,i think may be the list which contains the nodes have some memory limitations.
