hi,
when I am running my macro if the number of nodes is higher am getting the above error.
Any idea about this.
I used lists and 2 inner for loop for iterating through nodes.
Hi
Please replace {nodes $uniqueList} by 'nodes $uniqueList'
Hi Please replace {nodes $uniqueList} by 'nodes $uniqueList'
hi tinh,
Thanks .
But initially when I running the macro for small model it worked.
why its not working for big ones.
Maybe in small one, it does not call that command
Hi, Maybe in small one, it does not call that command
Thanks tinh.
the command gets the call.
As per iterations I done and some studies came across I,i think may be the list which contains the nodes have some memory limitations.
