🎉Community Raffle - Win $25
Join and Win
Hyperstudy & Dyna optimization
AmaskerUser: "Amasker"
Altair Community Member
Updated by Amasker
Hi,
I have a problem that puzzles me.
I use hyperstudy and Ls-dyna do to optimize composite design-related topics, but I do not know how to optimize composite ply thickness and the stacking sequence
Where can I find related cases or tutorials, thank you
1 - 26 of 261
    You could refer to HyperStudy quick start example where we have ply stack model, which covers ply thickness and stacking sequence as input variable.
    OP
    Updated by Amasker
    @Rahul R  Thank you,
    The solver in the above tutorial is Optistruct, can this optimization method be applied to Ls-Dyna?
    In addition, there are only 4 types of composite layups, and the final optimal layup order can only be derived from the four layup sequences set previously.
    Is it possible to optimize the layup thickness and layup order like Optistruct?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.323ce2b5e352834fa9161152e70f1897.png
    OP
    Updated by Amasker
    @Rahul R
    How to establish the connection between design variables in Hyperstudy?
    such as design variable 1 = design variable 2, or design variable 1 = (design variable 2+ design variable 3) / 2
    Can you give some advice? Thank you
    HyperStudy is Solver neutral.Optimization can be performed using the analysis solver directly, or by using a fitting function.For Linking Input variable , you could refer to below HyperStudy online tutorial.
    HS-1060.
    OP
    Updated by Amasker
    HS-1060.
    Thank you,Rahul R
    HS-1060 is a variable connection between different models. What I want to achieve is how to link two variables in the same model.
    This should work for same model also. See the screenshot shared in below post.
    https://community.altair.com/community?id=community_question&sys_id=fe96047a1b2bd0908017dc61ec4bcbe5
    OP
    Updated by Amasker
    Thank you Rahul R
    Here I have a question. When setting up a parameterization file, there is an option Attach to when defining the design variable. Is it possible to associate the design variable with this,
    which is different from establishing the Link
    OP
    Updated by Amasker
    Rahul R
    I have encountered a very difficult problem.
    When performing Hyperstudy and Dyna optimization, there is no problem with nominal run,
    but after each iteration of more than 10 times, I will report the error and terminate the calculation.
    I am very anxious and confused. I don’t know what to do, I can help me check the model?
    Which optimization method you are using?Also try by setting the ignore failed evaluation.
    OP
    Updated by Amasker
    @Rahul Raj Thank you very much
    The optimization algorithm I used is ARSM.and set the ignore failed evaluation. like figure 1
    But when the invalid iteration is more than 10 times,like figure 2. the optimization is automatically terminated. My .tpl file is too large to upload, and I don't know how to solve this urgent problem.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.9380fe13e1c33b79dcf318266a46ad63.png
    I see you are using HyperStudy 2017.1 and would suggest you refer attached document for ARSM based optimization algorithm for termination of optimization.
    OP
    Updated by Amasker
    Thank you,
    Is it possible to send the .tpl file to you, and check if it is wrong, but my .tpl file is too large to upload, is there any other way to send it to you?
    Why can't I find the MAXFAIL option?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.cd6300d7b78fa125b162b4f643e0b4d7.png
    OP
    Updated by Amasker
    Hi, @Rahul R
    I imported the .k file of the problem model into hypermesh, and the error shown in the figure appears. Why is this problem? how to solve this problem?
    <?xml version="1.0" encoding="UTF-8"?>1257044079_36020191111164222584.thumb.jpg.a3c3c993780704b04b2178cbbd57d557.jpg
    I don't think this is error.If it is error, then it would have listed out with some message in the status bar.
    Note: Its always recommended to use the latest version(For 2017version the latest patch was 2017.3 and for current version 2019 the latest patch is 2019.1)
    OP
    Updated by Amasker
    How to solve this problem,  is it related to the software version?
    Where can I download the latest version of hyperworks?
    OP
    Updated by Amasker
    Hi ,@Rahul R
    The composite layer I want to use is too much to be listed in the tutorial. Is it possible to optimize automaticly the layup thickness and layup order like Optistruct?
    OP
    Updated by Amasker
    Hi, @Rahul R
    I have a problem that has been bothering me for a long time.  my Velocity curve is too turbulent,as picture 2, I don't know how to set the filter function?
    How to add a filter function when setting the response in Hyperstudy,  Can Hyperstudy implement filtering?
    image.png.8d80e03be5a2070770e6ce407a30a970.png<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1ec0dfeaa98cb34fc2744ae82870e6af.png
    OP
    Updated by Amasker
    How to smooth the above speed curve in Hyperstudy?
    This is an urgent problem to be solved.
    Thank you
    Do you want to measure the difference between two curves for optimization?
    OP
    Updated by Amasker
    No, I want to make the above speed curve smoother, just like the speed curve in Hyperview. As shown in the figure below,
    is there a function that can smooth the curve?
    Hi Amasker,
    To smooth the curve in HyperStudy, you can use saefilter or polyfit functions available in the Expression builder. You would need to create data sources for each vector Time and Velocity and then create a Response defined with the filter expression.
    Hope it helps. Let us know if further questions.
    Diana
    OP
    Updated by Amasker
    Thank you @Mavrudieva
    Thank you very much for your answer, I recently recalculated it using Hyperstudy2019, and I have a doubt
    Why is there a test model option in each section? Is n’t it a waste of time,
    can I skip the test model option, and there is no hyperstudy2019 tutorial or Case? Thanks
    New definition concept is for more complex setups & allows more freedom to explore diverse studies in a single session.
    OP
    Updated by Amasker
    Rahul R,
    I have upgraded the software version from 2017.2 to 2019.1, but the same problem still occurs. I am very confused and do not know what to do.
    There were no problems in the first 12 calculations, and then an error was reported. After I opened the model file that was
    reported, I found that the angle of the composite layer changed to 50 and the thickness of the layer changed to 60.12. here is.study file。
    I'm in a hurry and don't know what to do。
    image.png.ef5fca405213c264336cb7ef6c61ea4c.png2084543782_36020191111164222584.jpg.2d176d113260e2c10f3569696aedcb1a.jpg
    OP
    Updated by Amasker
    Can anyone help solve this problem:unsure:/emoticons/default_unsure.png' title=':unsure:' />,?hurry, thank you
    OP
    Updated by Amasker
    Before optimization, Whether DOE test design is necessary?
    Is this the cause of the error in the middle of the optimization?
    Whether Hyperstudy can optimize the fitted curve or surface after FIT?
