🎉Community Raffle - Win $25
Join and Win
Run Exe file from tcl macro
User: "SriGanesh Doshaim"
New Altair Community Member
Updated by SriGanesh Doshaim
Hi,
I have converted .tcl file to executable (.exe)  file format. (The macro(.tcl) which works on Hypermesh )
Is it possible to call the .exe file from another .tcl macro?
exec [ file normalize 'c:\\hm\\Runexe.exe' ];
Or
Is there a way to secure the code?....Binary format or something...
Regards,
SriGanesh,.
1 - 12 of 121
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    How to convert .tcl script into .exe ? Do you use ActiveState tool ?
    OP
    Hi Q.NGUYEN-DAI,
    Thanks for your reply.
    I have used freewrap to convert .tcl to .exe. http://wiki.tcl.tk/11861
    Is there any way that we can convert the source code to any non-readable format?
    Regards,
    SriGanesh.
    User: "tinh"
    Updated by tinh
    Hi,
    Or
    Regards,
    SriGanesh,.
    Hi
    you can run exe file from tcl of hypermesh but i am not sure it can invoke hm tcl commands or not
    if you want to secure source code you can use tcl compiler
    wrapping tcl code will create independent exe file only (cannot source it in other tcl code)
    Altair Employee
    IMHO, the best tool in this case is use TCL Devkit from ActiveState (http://www.activestate.com/tcl-dev-kit ). It's not free tool but you can 'compile' your TCL script in binary form and source it like TCL script.
    User: "tinh"
    Updated by tinh
    Hi,
    there is a free TclPro1.4.1 you can download from sourceforge.net
    but it's not support some new syntax of tcl like 'eq', 'ne', '**',...
    OP
    Q.NGUYEN-DAI,
    Thanks for the opinion..
    I have installed the trail version of dev kit and compiled the source code which was created on hm..It source perfect and works fine...
    Is there any free tool to convert the tcl to bytecode...?
    tinh,
    I have installed TclPro1.4.1 from sourceforge.net. It is asking for license. Please suggest..
    Thanks,
    SriGanesh.
    Altair Employee
    @SriGanesh: Maybe there is another tool to do that. But at work, I use TDK so I'm sure that should work ok image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "tinh"
    Updated by tinh
    Q.NGUYEN-DAI,
    tinh,
    Thanks,
    SriGanesh.
    license is here
    http://www.tcl.tk/software/tclpro/eval/1.4.html
    if you use trial TDK then your tbc file will expire when trial time finished
    tclpro1.4 is free but it's written from 2000 so it cannot compile new syntax like **, eq, ni,.. you should care about these
    Altair Employee
    Hello,
    i'm also using TCLPro and it works fine for me. I don't use new syntax.
    The version is for free, including the licenses.
    Best regards,
    Mario
    OP
    Thanks all.. image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Your opinions and views helped a lot..
    Regards,
    SriGanesh.
    Altair Employee
    license is here
    Hello tinh,
    I have downloaded and registered the TCLpro, but how to compiler the tcl to bytecode with it?
    Regards,
    H.B
    User: "tinh"
    Updated by tinh
    Hi Herbert,
    you just follow it help document
    or open cmd console and type <installedDir>..../procomp /? for execution guide
