🎉Community Raffle - Win $25
Join and Win
hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I want to delete the non-manifold surface in hyper mesh, how can I do that.If not is it create any problem to analysis.
1 - 12 of 121
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    You can delete any surface in HM using the delete option (F2) then select surface from the drop down and select the surface and click on delete entity.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.c6976e33d0c2f8951b6b9366a3edf297.png
    For problems during analysis can you please tell me which solver you are using?
    Thankyou
    Altair Employee
    OP
    thanks for your reply, it is a shared surface between two bodies.I divided the body by using the trim with the plane option.I am using Optistruct as a solver.I uploaded the image below.
    If you are using OptiStruct, i don't think there will be any problem during Analysis.
    But if you still want to delete the surface you can follow the above stated procedure.
    Thankyou
    Altair Employee
    OP
    I want to repair the elements which don't have good element quality(aspect ratio, skew, jacobian) in the 2d mesh.How can I clean the mesh
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Show us your mesh? Share HM model?
    Altair Employee
    OP
    I uploaded the file.please check
    My suggestion about splitting plan:
    Altair Employee
    OP
    I am doing on optimization using Optistruct.For non-design space is it ok to split in that area you mentioned.
    Altair Employee
    OP
    what about quality checks like aspect ratio, Jacobian, skew.
    For design space you can simplify your geometry.
    For TRIA3 mesh, you not need check Jacobian (always = 1).
    Altair Employee
    OP
    how can I know created mesh is good for analysis.
    sorry for your inconvinience
    For TRIA3 mesh, I check often :
    • aspect <= 5
    • connectivity
    • duplicates
