Altair RISE
Nominate Yourself Now!
Hyperlink
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
  I need to take the file path of an exported H3D file and paste it in an excel. It should be like, The excel should display 'H3D' and when I click that, it should call that File path and open that H3D file. Can it be done? Any help is appreciated.
1 - 13 of 131
    Altair Employee
    OP
    Hi BeslyD,
    You can paste the path of the H3d file along with the file name as a HyperLink in Excel.
    When you click on the HyperLink,  HyperView player will open with the animation file loaded.
    Altair Employee
    OP
    Hi Prakash,
                     I did the same, but the problem is that the file path link is not getting converted as a hyperlink (So that I can directly open the H3D file Hyperview Player on one click of the link)
    Altair Employee
    OP
    Have you tried this?
    In MS Excel, Goto Insert>>HyperLink>>Existing File or webPage>>Select the H3d file and click OK.
    Altair Employee
    OP
    Hi Prakash,
              I can do it by this way and get the macro of it. Its is
        ActiveSheet.Hyperlinks.Add Anchor:=Selection, Address:= _
            'C:\Users\besly_t\Documents\A1.h3d', TextToDisplay:= _
    so for using in tcl, I am modifying it as
     set A1 'C:/Users/besly_t/Documents/A1.h3d'
    *writeh3dtofile $A1 1
     sheet Hyperlinks Add Anchor:=Selection
     Address:= $A1
     set dis [ TextToDisplay:= 'H3D' ]
    $cells Merge
    $cells Item 1 A $dis
    But I am getting syntax errors in these..
    Altair Employee
    OP
    Hi,
       I tried like this
    set cells [$sheet range a22 n22]
    $cells Merge
    $cells Item 1 A $A1
    $hyperlinks Add $anchor '' '$A1'
    But I am getting syntax errors in these again.
    Altair Employee
    OP
    Hi,
       I tried like this
    $cells Merge
    $cells Item 1 A $A1
    Altair Employee
    OP
    Hi,
       I tried like this
    $cells Merge
    $cells Item 1 A $A1
    Altair Employee
    OP
    Hi,
       I tried
                 $cells Merge
                 $cells Item 1 A $A1
    But I am getting syntax errors in these also.
    Altair Employee
    OP
    Hi,
       I tried
                 $cells Merge
                 $cells Item 1 A $A1
    Altair Employee
    OP
    Hi,
       I tried
                 $cells Merge
                 $cells Item 1 A $A1
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi what is $sheet ?
    Try access excel via dde facility instead, or twapi also support
    User: "tinh"
    Updated by tinh
    Hi what is $sheet ?
    Altair Employee
    OP
    Hi,
      Sorry for the multiple replies... I wrote the code for Hyperlink. Thank You
