🎉Community Raffle - Win $25
Join and Win
INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL DESCRIPTION :
User: "Kunal Hirudkar"
Altair Community Member
Updated by Kunal Hirudkar
HI @Rahul R,
I am trying a bottle simulation with radioss, I tried keeping all as simple as possible for simple test.
the file says
 .. ELEMENT BUFFER INITIALIZATION
WARNING ID :          312
 ** INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
DESCRIPTION :
    1 INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
 .. GEOMETRY PLOT FILE
 .. PARALLEL RESTART FILES GENERATION
     TERMINATION WITH WARNING
          0 ERROR(S)
          1 WARNING(S)
PLEASE CHECK LISTING FILE FOR FURTHER DETAILS
what shall I do with kinematic conditions?
1 - 2 of 21
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    the TOP_BCS load collector constrains all DOF, which is incompatible kinematic condition with the imposed displacement in the Y translational direction on the same node of a rigid body. Therefore Y translational DOF has to be free in the TOP_BCS load collector.
    Check unit consistency: the unit system declared in the BEGIN CARD is kg, m, s however the material parameters used are consistent with tonne, mm, s.
    OP
    Thank You. It worked.
