🎉Community Raffle - Win $25
Join and Win
Map initial deformation to mesh
User: "Bill_22179"
Altair Community Member
Updated by Bill_22179
I need to compute the stress in a beam that has plastic deformation. I dont know what are the initial stresses so I need to compute them.
The way I see it is I would mesh the beam (with solid/shell elements) first. Then I would add the deformed geometry to the model. I would then deform the initial mesh so it looks like the deform geometry.
Other than adding spcd to faces/nodes, is there a bette way to do this? Can this be an optimization problem?
I can't share pictures but you could imagine a beam fixed at both ends and warped in the middle.
Thanks
1 - 3 of 31
