🎉Community Raffle - Win $25
Join and Win
Altair EDEM simulator problem : it crashes
User: "Jihong Min"
Altair Community Member
Updated by Jihong Min
I downloaded Altair EDEM today and made example by watching "Mixing in Tablet Coater with Altair EDEM".
But, when I press simulator button, it suddenly stop without any error message.
(Image of my screne)
I will attach my file.. Plz help me.
1 - 11 of 111
    User: "phamad"
    Updated by phamad
    Hi there,
    I checked your files and saw you set the loop time of the rotation motion as equal to zero, you should try to use a non-zero value for that.
    Cheers,
    Dzung Pham
    User: "Jihong Min"
    OP
    Hi there,
    Cheers,
    Dzung Pham
    Do you mean that I should change "loop every" value?
    It doesn't work.
    User: "Stephen Cole"
    Altair Employee
    Accepted Answer
    Updated by Stephen Cole
    Hi,
    I believe this maybe an issue with the 2021.2 classroom version.  Can you try the 2021.1 version and this should run OK.  We are also going to be shortly releasing the 2022 version which should also have this issue resolved.
    You can find the 2021.1 version via the marketplace > search for EDEM > select Download > Choose 2021.1 from Suite Version:
    https://marketplace.altairone.com/Marketplace
    Regards
    Stephen
    It doesn't work.
    Hi,
    I managed to get it running after unticking the loop every X time checkbox. You could try this and if it does not work, I would recommend trying what Stephen Cole commented below. I hope that this helps.
    Kind regards
    Ignacio
    Hi,
    Kind regards
    Ignacio
    User: "Jihong Min"
    OP
    Hi,
    Regards
    Stephen
    It worked!
    thank you so much
    User: "Jihong Min"
    OP
    Hi there,
    Cheers,
    Dzung Pham
    stephen cole's way worked! Thank you
    User: "Suruthi Gnanenthiran"
    Updated by Suruthi Gnanenthiran
    Hi,
    Is this still an issue on the 2022 version? I am having the same issue of the software just closing when trying to use simulator
    Altair Employee
    Hi Suruthi, the issue is still with 2022, it should be fixed in EDEM 2022.2.
    Regards
    Stephen
    Regards
    Stephen
    Hi Stephen,
    Thanks for your reply. How do I get EDEM 2022.2 with a student license? I seem to only be able to download EDEM2022.
    Altair Employee
    Hi Stephen,
    Hi Suruthi, 2022.2 is currently in development.  The target release is the start of December.
    Regards
    Stephen
