Why does OptiStruct result differ greatly from those of ANSYS?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
91 - 98 of 984
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    If the same FE mesh, same material and the same BC, you have to get 'the same' results.
    So please check:
    • Mesh
    • MAT
    • BC
    Altair Employee
    OP
    So please check:
    • Mesh
    • MAT
    • BC
    Agree..
    Also, unit consistency, Did you scale the model by any chance?
    Altair Employee
    OP
    Did you validate the result?
    First, we need to investigate from which solver is the error is coming from.
    WIth just results values, it is difficult to come to a conclusion.
    The results of ANSYS are correct. I am solving same model with optistruct to get same results.
    Altair Employee
    OP
    So please check:
    • Mesh
    • MAT
    • BC
    Material and BC are all fine. Somewhat mesh is different. Because ANSYS meshes the model automatically whereas in hypermesh I did it manually. But I think it wont make such a big difference.
    Altair Employee
    OP
    Agree..
    Yes, I have cross verified the total mass of the model. Also checked units of Density, E and Poissons ratio. All are fine
    That's IMPOSSIBLE !!!
    I don't 'believe' to you until you show/share us two your models.
    Altair Employee
    OP
    @Rohit Ch
    I am sorry, with limited information, it is very difficult to judge.
    User: "gopal_rathore"
    Updated by gopal_rathore
    Sorry I cant share the result file as it is confidential. But i can share values of natural frequencies.
    in Optistuct first natural frequency is 13.87 Hz
    in ANSYS wb first natural frequency is 594 Hz
    So can u plz tell me what are the possibilities of wrong input data??
    The difference shown above is huge. Definitely modelling difference is expected in terms of fe steps. To conclude atleast share images of both cases showing constraint , system masses, frequency results etc.
91 - 98 of 984
