For Modal and Stiffness(torsional and bending) of ladder frame chassis, is there any significant difference in results when I use stick contact between frame and cross-members or when I use shell/rigid weld elements to connect cross-members and long members?
Hi,
Yes, I think you will see a difference with the stick contact and rigid welds.
Stick is a condition which tells the solver that two components should stick to each other when they come in contact.
