Altair RISE
Nominate Yourself Now!
Press fit analysis
User: "Punith"
Altair Community Member
Updated by Punith
Hello everyone,
basically I wanted to simulate the pressfit. I dont know if this is the right way to do. I already worked with the basic tutorial existing in website using PCONT card where we define the clearence. In my model there is a clearence already included. So I thought of trying with non-linear quasi static large deformation and I ended with an error. I have attached my model.  Also what is the better way to simulate pressfit ( I want to simulate the complete pressfit process). I have no knowledge with Radioss explicit solver. Please help me.
Thanks and regards,
Punith Guptha
31 - 44 of 442
    User: "Nachiket Kadu_22143"
    Updated by Nachiket Kadu_22143
    @Prakash Pagadala
    ok I understand that. Thank you for the reply.  Now to avoid such a mistake next time how can I export the intermediate results. For example the solver has performed the iterations upto 92% load now and looking for convergence. But I would like to see my results at 91% load. How can I do that?. Please help me.
    To view previous iteration you can use NLOUT.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Yes, you can still use NLOUT and also you use NLMON to monitor Nonlinear simulation
    User: "Punith"
    OP
    Updated by Punith
    But NLOUT is already used in the model. I do not see any H3d file in the location.
    For that in control card you need to switch NLMON=Disp.
    As far as i remember NLOUT= write last non convergent file
    and NLMON= write all iteration in seperate H3D
    Correct me @Prakash Pagadala if i am wrong?
    User: "Punith"
    OP
    Updated by Punith
    OK thank you @Nachiket Kadu and thank you @Prakash Pagadala
    User: "Punith"
    OP
    Updated by Punith
    @Prakash Pagadala
    I have a question regarding axisymmetric analysis. Is there any option available in Hyperworks for axisymmetric problem like in Abaqus?.If not, is Hyperworks working on that?.
    I have a cylindrical component andI would like to mesh only 2D crosssection of it and finally see the results for 360 Degree. How can it be done?. I tried defining the symettric constraints for the 2D mesh and defined the line contacts between the mesh. But it is not working. I contacted Hyperworks-Germany support team and they said that line contact is not working with Optistruct. How can I solve my problem? I am not able to work with 3D model as it is taking lot of time. Please help me in this concern.
    I am basucally looking to some parameter study for pressfit analysis of rim and disc by varing the length of press fit and angle and I am looking for the optimum. I think this problem can be handeled in Hyperstudy. This problem is non-Linear and if I work with 3D it takes huge time.
    Regards,
    Punith
    Altair Employee
    Hi Punith,
    Is it possible to share the axisymmetric problem from Abaqus (PDF should do)?
    I will check if I have any information.
    User: "Punith"
    OP
    Updated by Punith
    Hi Prakash,
    you can check the link below. I am looking for the similar application.
    Regards,
    Punith
    User: "Punith"
    OP
    Updated by Punith
    Hello @Prakash Pagadala,
    any recent update on this?
    Regards,
    punith Guptha
    Altair Employee
    Hi Punith,
    This is possible in RADIOSS
    Here is a reference: RD-E: 0800 Hopkinson Bar
    User: "Punith"
    OP
    Updated by Punith
    Hi @Prakash Pagadala,
    thank you for the reply. Let me have a look at it.
    Regards,
    Punith Guptha
    Altair Employee
    Hello@Prakash Pagadala ,
    I am just asking about the file for the Hopkison Bar as the example requires the input file.
    Input File
    High_strain_rate: <install_directory>/demos/hwsolvers/radioss/08_Hopkinson_Bar/High_strain_rate/SHPB_H*
    Low_strain_rate: <install_directory>/demos/hwsolvers/radioss/08_Hopkinson_Bar/Low_strain_rate/SHPB_L*
    Thanks!
    Altair Employee
    Altair Employee
    @Prakash Pagadala ,
    Thanks!
31 - 44 of 442
