🎉Community Raffle - Win $25
Join and Win
How to plot Hourglass percentage increase and % added mass increase of Radioss run in HyperGraph?
Hello,
I completed crash run in Radioss solver.
I want to plot % mass increase for crash run and % hourglass energy increase with respect to total energy in HyperGraph.
Thank you
1 - 1 of 11
    In your jobnameT01 file, (you will have one, but if you did not specify /TFILE frequency in engine it may have only 1 point in it) You can plot Mass (absolute) this includes added mass and lumped mass and structural mass, and Hourglass Energy and Internal Energy
    Then you can define a curve as 'delta mass' and subtract from it your structural mass (reported in your 0000.out): as a math curve (in my case this is .709 Tonnes)
    Then you can create another curve which is your (Delta Mass / Original Mass) * 100 to get percentage
    In my case, just over 3% at the end which agrees with my 0001.out file
    For Hourglass as a percentage of Internal: you can divide one by the other and multiply by 100 (I can't show the curve in my case as my hourglass is 0 (I'm using QEPH elements), you may need to tweak it slightly as if internal energy starts at 0, this would create a div/0 at the start of the curve (you could trim the first few points)
