Excessive Mesh Deformation
Hello ,
I am compressing a rubber component for large disp. analysis with MATHE card.
I am getting an error saying run stopped due to excessive mesh deformation. My mesh is already much fine. I have increased number of iterations and increment (Basically I have played with NLPARM a lot). If I make my mesh finer then it takes a lot of time to solve. What might be the remedy for this problem?
Also I want my material to become hard if I compress it. In mathe card I have given a Stretch strain curve with such a profile. But While in analysis in reality I get very small disp as compared to FEA results. This happens generally when my disp. is larger. can someone tell me the solution for that?
Regards,
Bharat
1 - 1 of
11
Could you share us .out file?
Regards
Rahul R
