🎉Community Raffle - Win $25
Join and Win
Road modeling
User: "draucis"
Altair Community Member
Updated by draucis
Hello,
I have been studying about road modeling and I have generated a random road from Matlab. The coordinates I have, are for x and y and does not represent the vertices of a triangle, so how can I use PCD to model road or are there any other alternatives.
The Matlab code I have used is based out of ISO 8608. Any insights on this will be helpful.
If anyone needs any data regarding this, I can provide that.
Regards
Draucis
1 - 6 of 61
    User: "Jagadeesh R"
    Altair Employee
    Updated by Jagadeesh R
    hi Draucis,
    I have attached easy way to model the PCD road using hypermesh to create and export .fem along with the format required.  hope this will help you.
    thanks,
    jagadeesh
    User: "draucis"
    OP
    Updated by draucis
    hi Draucis,
    thanks,
    jagadeesh
    Hello Jagadeesh,
    Thanks a ton for your help, yes it definitely helped as I was looking forward to understanding PCD road for a while now. Still my problem remains as the data I have from MATLAB is different and I want to make a road profile out of it. Sorry for a lack of better understanding but from the file I have attached are you able to understand anything of how to use that data in a road file, because I don't have a clear image yet.
    Regards
    Draucis
    User: "Jagadeesh R"
    Altair Employee
    Accepted Answer
    Hello Jagadeesh,
    Regards
    Draucis
    hi Draucis,
    you can use 3D spline road file from MV installation folder "....\hwdesktop\hw\mdl\autoentities\properties\Tires\ALTAIR_ROADS" and replace the xyz coordinates with available excel/matlab derived data and create the road using road tool. The additional information like obstacles can be deleted if they are not required. I have attached a sample road created using 3D spline for your reference.
    thanks,
    jagadeesh
    User: "draucis"
    OP
    Updated by draucis
    hi Draucis,
    thanks,
    jagadeesh
    Hi Jagadeesh,
    Thank you I think this will work out. I will try this out. I cannot see the attached reference file though. It's fine I'll try it out anyways.
    Thanks
    Draucis
    User: "Jagadeesh R"
    Altair Employee
    hi Draucis,
    thanks,
    jagadeesh
    hi Draucis,
    please find the sample road attachment.
    thanks,
    jagadeesh
    User: "draucis"
    OP
    Updated by draucis
    hi Draucis,
    thanks,
    jagadeesh
    Thanks, Jagadeesh. In helping terms you are a God to me.
    It's getting repetitive in saying thanks, I hope you don't mind but Thanks again for helping out.
    Regards
    Draucis
