Hey,
I have a question to run RADIOSS with GPU accelaration. I go through some handbooks and saw to run RADIOSS on a desktop pc with GPU support is possible, right? Is there a list of supported CUDA devices and/or need some special software?
My question in general is it possible to set it up for a desktop PC the GPU support (at the moment I#m using linux 64bit and Hypermesh is running)?
By the way I have a additional question. I'm running Hypermesh on a Linux openSuse System and it is running but unfortunately Hypercrash isn't running - it stops after the starting screen - do you know why?
Best,
Max
