Altair RISE
Nominate Yourself Now!
Page Height and width setting
User: "Vikas Kumar_22189"
Altair Community Member
Updated by Vikas Kumar_22189
Dear all,
Can we set heigh and width of a page or window in Hyperview ?
Is there any API available ?
<?xml version="1.0" encoding="UTF-8"?>Height_Width.thumb.PNG.9d287e5fd45cfcd1e5a3df480b1423ba.PNG
I am asking about ' h ' and ' w '.
@tinh
Regards,
Vikas Kumar
1 - 9 of 91
    User: "tinh"
    Updated by tinh
    Hi,
    we will add paddings to its frame:
    proc p_SetGraphicArea {Width Height} {
      set gframe .mainFrame.center.f3.center_frm.graphicfrm
      set pinfo [pack info $gframe]
      set pmaster [dict get $pinfo -in]
      set pmasterH [winfo height $pmaster]
      set pmasterW [winfo width $pmaster]
      set padX [expr ($pmasterW-$Width)/2]
      set padY [expr ($pmasterH-$Height)/2]
      set padX [expr $padX<0?0:$padX]
      set padY [expr $padY<0?0:$padY]
      pack configure $gframe -padx $padX -pady $padY
    OP
    Thanks @tinh
    It's working fine.
    If we wants to go back to original size how it can be done ?
    Since while i am adding new page it is taking same size but i need again original size in new page.
    Regards,
    Vikas Kumar
    User: "tinh"
    Updated by tinh
    Hello Vikas
    below last line will return original size, so you can remember them and restore graphic size later
      list $pmasterW $pmasterH
    example:
    # change graphic size to (200,100)
    set OriginalSize [p_SetGraphicArea 200 100]
    # do something with graphic image...
    #change graphic size to original:
    eval p_SetGraphicArea $OriginalSize
    OP
    @tinh
    Can we do the same or can we create multiple viewport in hypermesh.
    I know manually it is not possible.
    Is there any tcl/tk command is there which can create multiple window in hypermesh.
    Regards,
    Vikas Kumar
    User: "tinh"
    Updated by tinh
    If there is a such command, altair has already bring it to GUI
    I know there is a way, but it may not be same as hyperview
    My ideal is invoke a second hypermesh, show only its graphic window, and embed it in to a frame beside 1st hm graphic area. As they are different process, you cannot use model browser or panels of the 1st to manipulate the 2nd, that is not same as hyperview
    But if you just need to see 2 viewports, eg to make report, it is fine
    OP
    User: "zeta1234"
    Updated by zeta1234
    Hello all,
    @Vikas Kumar , I have got the same query as your, But i have to get some more info shown in the figure below. This information is required in capturing an animation (by area). @tinh you have already provided valuable information above but i cannot understand the procedure. There are keywords like .mainFrame, .center., etc. that i cant find in hyperview documentation. Maybe you can share me the link.<?xml version="1.0" encoding="UTF-8"?>Untitled.thumb.png.2b5fe97ef3a51a122d7de03b897721d9.png
    Looking forward for solution :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> , Thanks all in advance
    OP
    Hello all,
    Hi Zeta,
    Give me some time i will provide you same info.
    Regards
    Vikas
    User: "zeta1234"
    Updated by zeta1234
    hi @Vikas Kumar , did you get any information regarding my query. Looking forward for your inputs.
    Have a nice Monday :)
    Thanks and Regards
