How do you stop the simulation in HyperMesh CFD and then how to continue simulation?
Hi! I´m doing some heavies meshs, and my computer is not very powerfull to simulate them in one day. Also I cannot use all the day my computer only for doing a simulation, i have another things to do. I always try to stop the simulación in the "run status" by right clicking and clicking "Stop", but the program does not respond. Can anyone give me a solution?
The 'Stop' button would send a 'signal' to the solver. Once that signal is caught by the solver, it will complete that current time step, and write whatever output/restart files have been requested. If a time step takes a long time to complete - the job will take a long time to stop.
To start it again, you would go into the Restart portion of the launch panel, and indicate the appropriate entries.
Thanks you very much!!! Now I can stop and continue the simulations
https://help.altair.com/hwdesktop/cfd/topics/pre_processing/solution/acusolve_simulation_run_t.htm#acusolve_simulation_run_t
