🎉Community Raffle - Win $25
Join and Win
Optistruct output
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
I want to check angle of deformation from this pendulum.in terms of angle which its moving from the center.
what inputs i need to have and how to calculate in hyper works. this problem is solved in optistruct.
Thanks in advance . <?xml version="1.0" encoding="UTF-8"?>Diss.thumb.gif.6510e1f971765ac48725f7b760c9aaae.gif
1 - 5 of 51
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Did you try making a tracking system at center?
    Altair Employee
    OP
    are you sure what do you need?
    realy? angular deformation?
    or displacement angle?
    Altair Employee
    OP
    i want to calculate the angle which is tilted from the center its FRF with X axis.
    please find attached gif for complete information.
    Altair Employee
    OP
    Hi tInh
    No i haven't
    can you please explain  what need to be done here ?
    Thanks
    sharan
    User: "tinh"
    Updated by tinh
    In hyperview, enter panel 'tracking'
    create a tracking system at center of the hole
    base on it you can calculate angle
