🎉Community Raffle - Win $25
Join and Win
Adding materials to different regions
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I want to add materials to different regions of the FEKO union geometry. When, I right click the region of interest and go to properties  only 2-3 medium available from the region medium drop down menu. Even, I add a medium by using the + sign, the medium only goes to media tree but can not select from the drop down menu.
I did  not have this issue with simple non-union geometries.
Please share if you know how to solve this problem.
Thanks in advanced.
1 - 3 of 31
    Altair Employee
    OP
    Hi csbk,
    If the media is defined it should be listed in the model tree and you can assign it to the selected region. It would be great if you could share the model so that we can investigate the problem properly.
    User: "Johan_Huysamen"
    Altair Employee
    Updated by Johan_Huysamen
    Dear csbk
    From your description it sounds like you might have a similar situation to the one described in this issue:
    Altair Employee
    OP
    Dear csbk
    This is exactly the same problem ,I am facing.  Thanks Johan.
