Print Body Temperatures - User Customized Results
covadonga
covadonga Altair Community Member
edited October 2020 in Community Q&A
I am running a very simple model in which I am evaluating the relative thermal displacement of several bodies, and so, I am forcing some temperatures in the bodies. It is a linear analysis in which Temperatures are the input.  How can I plot the temperatures in the results?
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited June 2020
    In H3D results, no code for temperature?
  • covadonga
    edited June 2020
    Hello Q.Nguyen-Dai, In my model, the temperatures are forced, they are input.  However , I am insterested on the plot.  How do i request Temperatures as an output?
    I was an Ansys user, while post-processing you can request there customer defined results, and request the temperatures with a code. Is that what you are referring to?
  • QuyNguyenDai
    edited June 2020
    As the temperature is your input, you know well on it.
    So have a look at Altair's help with keyword 'hwascii' you will found how to put input temperature in a HWASCII format for post-processing.
  • covadonga
    edited June 2020
    Hi, I found the way to write temperatures in the output file by requesting it in the output card.
    CARDS >>GLOBAL_OUTPUT_REQUEST>>OLOAD
    Cheers
Welcome!
Welcome!
