Print Body Temperatures - User Customized Results
I am running a very simple model in which I am evaluating the relative thermal displacement of several bodies, and so, I am forcing some temperatures in the bodies. It is a linear analysis in which Temperatures are the input. How can I plot the temperatures in the results?
In H3D results, no code for temperature?
0 -
Hello Q.Nguyen-Dai, In my model, the temperatures are forced, they are input. However , I am insterested on the plot. How do i request Temperatures as an output?
I was an Ansys user, while post-processing you can request there customer defined results, and request the temperatures with a code. Is that what you are referring to?
0 -
As the temperature is your input, you know well on it.
So have a look at Altair's help with keyword 'hwascii' you will found how to put input temperature in a HWASCII format for post-processing.
0 -
Hi, I found the way to write temperatures in the output file by requesting it in the output card.
CARDS >>GLOBAL_OUTPUT_REQUEST>>OLOAD
Cheers
