RBE3 Weight factor calculation
Yes, I have to specify,
but in ACM weld creation method RBE3 is created and upon reviewing element, it will have different weight factor values. How do I get those values here? is there any formula to calculate weight factor?
i think it is specified by you, input it in update subpanel. default to 1.0
so in panel connector>spot, you press F1 and will find out how the values calculated /emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20' />
