🎉Community Raffle - Win $25
Join and Win
Membrane elements
User: "FabioC"
Altair Community Member
Updated by FabioC
Dear users,
I am running a modal analysis in Optistruct for a simple 2D plate in order to validate some Matlab scripts.
I use CQUAD4 elements (PSHELL 2D property) in HM.
Results from OS are consistent if I compare them with a 6-DOF per node element in Matlab.
Now, I would like to compare the same case for membrane elements (2-DOF per node) but I am not able to find a way to model a membrane in HM.
Any suggestion about a different element?
Thank you
Regards
Fabio
1 - 2 of 21
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    https://community.altair.com/community?id=community_question&sys_id=9c96007a1b2bd0908017dc61ec4bcba4
    for Optistruct the following behavior are valid:
    - To model a membrane plate, use only MID1
    - To model a plate with bending stiffness only, use only MID2
    - For bending with transverse shear flexibility, use MID2 and MID3
    - Use MID3 to include an extra shear term in the element stiffness calculations (i.e. includes transverse shear flexibility).
    - For a solid homogeneous plate, MID1, MID2, and MID3 should reference the same material ID
    - MID4: The MID4 field (bending and membrane deformation coupling) should be defined only if the element’s cross section is unsymmetric. Default is blank = symmetric cross section.
    (Note: Mass is not calculated if MID1 is blank.)
    In summary, the results of leaving an MID field blank are:
    ●MID1: No membrane or coupling stiffness or Mass
    ●MID2: No bending, coupling, or transverse shear stiffness
    ●MID3: No transverse shear flexibility
    ●MID4: No bending-membrane coupling
    The standard for typical shells (thickness about 1/15 of size) is to use the same ID for MID1, MID2 and MID3.
    To define a membrane, please leave MID2 and MID3 blank on the PSHELL property, or use PARAM,SHL2MEM.
    User: "FabioC"
    OP
    Updated by FabioC
    Thank you @Hyperman. Late reply, but solved it!
