Instruction explanation of Contact
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
I am learning about contact's instruction
but help's explanation I can't understand about it explanation
I just want to know about
Orientation of Contact Pushout Force (MORIENT)
Contact Adjustment (ADJUST)
Contact Clearance (CLEARANCE)
how do this three instruction explain
thanks a lot
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    Hi @LKZ
    Did you read this section on help?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    Hi @Prakash Pagadala
    I have read this in help
    <?xml version="1.0" encoding="UTF-8"?>5a705892ce696_.thumb.JPG.180d52b28bf5d9ca09455ba5f40a467c.JPG
    but I can't understand about it's explanation..
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2018
    Hi,
    ADJUST: Contact ADJUST parameter allows slave nodes to precisely contact the master surface. This is useful to eliminate small gaps or penetrations during preprocessing.
    CLEARANCE: The CLEARANCE utility allows user-specified precise initial clearance or overclosure values. See the image with zero clearance and with positive clearance. WIth zero, contact becomes active immediately but with 0.7 contacts become active when the relative displacement between slave and master becomes 0.7
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thanks a lot!
Welcome!
Welcome!
