SCRIPT 1064 - Create one prop + one system per element to define orientation issue
Hi,
Could you please help me? I am an user Hypermesh who would like to use
'SCRIPT 1064 - Create one prop + one system per element to define orientation' I downloaded this script form 'https://connect.altair.com/CP/script-list.html' but I found one issue that (mapping.txt and hmresdmp.txt) both of files have some issue. In these files show FILE QUARANTINED The Altair Germany Systems team would like to inform you that the email server anti-virus scanner found a potentially dangerous attachment in your message. The attachment was removed from your message, and the message recipient cannot access it. The attachment will be quarantined for 4 weeks. Please contact de-systems@altair.de for any question you may have about this. Original filter message follows: Microsoft Forefront Protection for Exchange Server EUEXCH removed a file since it was found to match a filter. File name: 'src.zip->hmresdmp.exe' Filter name: 'FILE FILTER= EUEXCH-1 FOREFRONT ATTACHMENT BLOCK RULE: *.exe' Thanks, Jame |
