🎉Community Raffle - Win $25
Join and Win
Empty volume regions error
User: "Magbee H"
Altair Community Member
Updated by Magbee H
Hi,
I solved a lot of problems using Flux. But this time, Flux keeps giving me this error shown below and the project can't be solved:
Even if I deleted volume4, the error would keep coming and change to another volume.
Can anyone please tell me how to fix this?
1 - 4 of 41
    User: "SimonGuicheteau"
    Altair Employee
    Accepted Answer
    Updated by SimonGuicheteau
    Hello
    you don't need to worry about this message. This only means that the fourth Volume region is not assigned to anything. Most of the time it does not matter, this property will not be used in the solving.
    If all your regions should be used, then try checking that they are assigned correctly.
    Best regards
    User: "Magbee H"
    OP
    Updated by Magbee H
    Hello
    Best regards
    Hi
    Thank you so much for replying! After deleting the unused volume, the problem can be solved. It shows correctly solved but I still get this error: Failed execution. Do you know what this means and how to fix it? Can I trust the solved values?
    Thanks again and best regards!
    Hi
    Hi Magbee,
    These messages are related to the display and don't have any effects on the results.
    Thank you,
    Lavanya
    User: "Magbee H"
    OP
    Updated by Magbee H
    Hi Magbee,
    Thank you,
    Lavanya
    Thank you for replying!
