🎉Community Raffle - Win $25
Join and Win
License Error
User: "Stef"
Altair Community Member
Updated by Stef
When trying to run Feko, I am encountering the following license error:
Altair Feko - SECFEKO Version 2021.1-14 from 2020-05-29
(compiled for target PC_WIN64_EM64T_MKL, 64 bit)
ERROR 9161:
An error occurred while checking out a licence
Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWFEKOGUI
Error Code: 9
Error Description:
Feature not found
Feature: FEKOGUI
Error Code: 51
Error Description:
[LOCAL] D:\Programs\Altair\Feko\security\altair_lic.dat - (Err: 51) Unable to use network license as a local license
License Path: D:\Programs\Altair\License\altair_lic.dat;D:\Programs\Altair\Feko\security\altair_lic.dat
Would anyone know how to solve this? I have:
  • Created an environment variable pointing to the license .dat file
    • image
  • Ensured that the license file is named altair_lic.dat and not altair_lic.dat.dat
  • Copied the altair_lic.dat file to the security folder of Feko. In my case D:\Programs\Altair\Feko\security\altair_lic.dat
    • image
  • Made sure the MAC address of my device corresponds with the one seen in the license file
  • Installed Altair License Manager and I am seeing this:
  • Tried restarting the Altair License Server from Services.msc
  • Restarting the computer
  • Reinstalling Feko
  • Installing an older version of Feko
Any help or troubleshooting tips would be appreciated.
1 - 5 of 51
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    hi,
    what kind of license do you have? Is it student version? Or a server license?
    You would only need the license manager, IF it is a server license (usually commercial license), and IF your machine is the server.
    User: "Stef"
    OP
    Updated by Stef
    Hi Adriano
    I think it is a server license.
    Altair Employee
    Hi Adriano
    Hi,
    you need to know what type this is, so the procedure is right.
    Where did you get this license from? Are you a customer of Altair? Or is it Student version?
    User: "Stef"
    OP
    Updated by Stef
    Hi,
    I received the license from my workplace who is a customer of Altair. I believe that it is a server license.
    Altair Employee
    If it is a server license, you will need to:
    1) install Altair License Manager
    2) during installation you will be prompted for the license file, which will be moved to C:\Altair\licensing14.5.1\altair_lic.dat
    3) once the license server is running (you can check in 'Services' if 'Altair License Server' is started and running
    4) now, for ALL CLIENT machines, including your own, you will need to create a environment variable ALTAIR_LICENSE_PATH = 6200@name_or_IP_of_server_machine   >> in your particular case, this will point to your own machine, as it is the server.
