Altair RISE
Nominate Yourself Now!
Component name look up for connectors
User: "Vlad VB"
Altair Community Member
Updated by Vlad VB
Hello,
    Can some one help me with dissecting component names. I have a multiple assemblies one has components other has weld lines. Weld lines have base components name in it.
Example  of a weld line component name
    2 layer line
                LA7273333/2-012234 WLD LNS (X02704/X03430)
    3 layer line
                LA72733425/2-010104 WLD LNS (X513A12/X02704/X03430)
Example of components names
                   AA6383837/5-XXXX-X02704-A (PLR FRT uPPER RR FRONT)
                  AA671617033/5-XXXX-X03430-A (SHLD HDR REINF)
                  LAA6716635/4-XXXX-X513A12-A (RL RF SD FRT LHS)
I would like to look inside the weld line assembly pull out a name of the weld line sort 2 layer of 3 layer based on name inside the ( ), use the naming inside ( ) from a line name, find the components and create a connector.
Thank you for any help
1 - 8 of 81
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Vlad,
    you can refer below for an idea on how to do this.
     set lst_weldcompData [list 'LA7273333/2-012234 WLD LNS (X02704/X03430)' 'LA72733425/2-010104 WLD LNS (X513A12/X02704/X03430)'] set lst_components [list 'AA6383837/5-XXXX-X02704-A (PLR FRT uPPER RR FRONT)' 'AA671617033/5-XXXX-X03430-A (SHLD HDR REINF)' 'LAA6716635/4-XXXX-X513A12-A (RL RF SD FRT LHS)'] foreach str_weldcomp $lst_weldcompData {     set str_comp1 ''; set str_comp2 ''; set str_comp3 '';    set str_simplified [ regsub {\)} [lindex [split $str_weldcomp (] end] '']    lassign [split $str_simplified / ] str_tempcomp1 str_tempcomp2 str_tempcomp3;    puts '$str_tempcomp1 $str_tempcomp2 $str_tempcomp3'    if {$str_tempcomp1 != ''} {     set str_comp1 [lsearch -inline $lst_components *$str_tempcomp1*]    }    if {$str_tempcomp2 != ''} {     set str_comp2 [lsearch -inline $lst_components *$str_tempcomp2*]    }    if {$str_tempcomp3 != ''} {     set str_comp3 [lsearch -inline $lst_components *$str_tempcomp3*]    }    puts '$str_weldcomp has $str_comp1 , $str_comp2 , $str_comp3' }
    User: "Vlad VB"
    OP
    Updated by Vlad VB
    Question on creating a list based on the names. I'm trying to create a list (lst_weldcompData) for the components that I have in a model which contain WLD LNS with following
    *createmark comps 1 'contains value' name WLD LNS* 1
    set lst_weldcompData [hm_getmark comps 1]
    I'm not getting anything from it
    for the second list I will select all components which contain SHELL elements
    proc Isolate2D {{opt all}} {
       *displaynone
       *createmark elems 1 $opt
       *createmark elems 2 'by config' tria3 quad4
       *markintersection elems 1 elems 2
       if {[hm_marklength elems 1]} {*findmark elems 1 0 1 elems 0 2}
       *clearmark elems 1
       *clearmark elems 2
    Isolate2D
     *createmark comps 1 'displayed'
    set lst_components [hm_getmarkvalue comps 1 name 1];
    Thank you for all your help
    User: "llyle_20499"
    Hi Vlad,
    You can try:
         # search weld     set lst_compNames [hm_entitylist comps name]     set lst_weldcomps [lsearch -all -inline -glob $lst_compNames *WLD LNS*]      # search shell     *createmark elems 2 'by config' tria3 quad4     set lst_shellcomps [lsort -unique [hm_getvalue elems mark=2 dataname=component.name]]
    User: "Vlad VB"
    OP
    Updated by Vlad VB
    when I execute line
    I get this error
    : must be -all, -ascii, -decreasing, -dictionary, -exact, -glob, -increasing, -index, -inline, -integer, -nocase, -not, -real, -regexp, -sorted, -start, or -subindices
    Thank you for your help
    User: "Vlad VB"
    OP
    Updated by Vlad VB
    its seems like its doesn't like Space in the 'WLD LNS' so naming of the component will need to change or is there a way around it?
    Thank you
    User: "llyle_20499"
    yes, special characters like space ( ) will case issues. You write a script to rename all components by converting all special chars to _.
    User: "tinh"
    Updated by tinh
    when I execute line
    I get this error
    Could you try again:
    set lst_weldcomps [lsearch -all -inline -glob $lst_compNames '*WLD LNS*']
    if '*WLD LNS*' has special character other than space, you can filter it by:
    set lst_weldcomps [lsearch -all -inline -regexp $lst_compNames {.*WLD[:space:]*LNS.*}]
    or if you are sure that component names don't have WLD and LNS then simply:
    set lst_weldcomps [lsearch -all -inline -glob $lst_compNames '*WLD*LNS*']
    User: "Vlad VB"
    OP
    Updated by Vlad VB
    Tinh,
       Thank you both methods worked
