🎉Community Raffle - Win $25
Join and Win
How to Create widgets like label frame in HM framework tab
Hi ,
I am trying to create a UI in the Tab  in HM itself.  i inserted some widgets like label frame, radio button , button etc.
  • in this label frame not showing , how to create a label frame i tried this code with help of   hwtk GUI toolkit.
Kindly help me to solve this issue and guide me how to create a UI in HM _framework
I attached the image and code which i used for your reference
################################################CODE##################################################################
#setting the mainframe
        set mainfrm [frame .frm1]
    # Adding the Tab
        hm_framework addtab 'Queries' $mainfrm
    # creating a subframe
        set subfrm [frame $mainfrm.frmmain1 ]
        pack $subfrm -side top -fill both
    # creating lable
        #pack [label $subfrm.lb1 -text 'Query Report Generation' -width 60] -side left -fill x -expand 0
    # creating label frame for TGW
        pack [labelframe $subfrm.lblfrm -text 'TWG_Report'] -pady 4
    # #Radio Button in the label frame
         pack [radiobutton $subfrm.rdbtn -text 'TWG'] -side top -fill x -pady 2
    # creating a screen shot button
        pack [button $subfrm.btn -text 'snap shot'  -command 'On_Select_SnapShot' ] -side top -fill x -pady 2
    # creating a Presentation for TGW
        pack [button $subfrm.btn1 -text 'Genrate'  -command 'Generate_Report' ] -side top -padx 2 -pady 2
output which i got
BUTTON AND RADIO BUTTON AND IS THERE BUT LABEL FRAME IS NOT THERE.HOW TO CREATE THAT LABEL FRAME
Thanks & Regards
Suresh Kumar V
1 - 4 of 41
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hello Suresh,
    Try label frame using the below example:
    # hwtk::labelframe
    hwtk::dialog .dlg
    set w [.dlg recess]
    # A group of radiobuttons in a labelframe
    hwtk::labelframe $w.f -text 'Value';
    pack $w.f -side left;
    foreach value {1 2 3 4} {
        hwtk::radiobutton $w.f.b$value -text 'This is value $value' -variable lfdummy -value $value
        pack $w.f.b$value -side top -fill x -pady 2
    hwtk::labelframe $w.f2
    hwtk::checkbutton $w.cb -text 'Use this option.' -variable lfdummy2
    $w.f2 configure -labelwidget $w.cb
    pack $w.f2 -side left -padx 4 -anchor nw
    set t 0
    foreach str {Option1 Option2 Option3} {
        hwtk::checkbutton $w.f2.b$t -text $str
        pack $w.f2.b$t -side top -fill x -pady 2
        incr t
    .dlg post;
    Hi livillyle ,
    Thanks for reply , but see you creating those widgets in a dialog but i am try to create those widgets in hm framework.see the image which i added i directly adding the widgets in tab which i created in HM UI itself.Kindly help how can i create a label frame in HM framework
    Thanks & Regards
      Suresh Vijayan
    Hello Suresh,
    The below code displays labelframe in hmframework.
    set mainfram [frame .mainfram];
    hm_framework addtab 'Queries' $mainfram;
    set frm1 [frame $mainfram.frm1];
    pack $frm1 -side top -fill both;
    set label1 [hwtk::labelframe $frm1.label1 -text 'Value'];
    pack $label1 -side left;
    set rbutton1 [hwtk::radiobutton $label1.rbutton1 -text 'Button1' -variable nil -value 1]
    pack $rbutton1 -side top -fill x -pady 2
    set rbutton2 [hwtk::radiobutton $label1.rbutton2 -text 'Button2' -variable nil -value 2]
    pack $rbutton2 -side top -fill x -pady 2
    set rbutton3 [hwtk::radiobutton $label1.rbutton3 -text 'Button3' -variable nil -value 3]
    pack $rbutton3 -side top -fill x -pady 2
    set rbutton4 [hwtk::radiobutton $label1.rbutton4 -text 'Button4' -variable nil -value 4]
    pack $rbutton4 -side top -fill x -pady 2
    Regards,
    LL
    Thanks a lot livillyle ,
    Its Working fine
    Regards
    Suresh V
