🎉Community Raffle - Win $25
Join and Win
diffrent thickness assign on mid surfaces
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have problem with thickness assign, i have only one mid- surface that comes from an assembly and i wanna assign different thicknesses to componets of this surfaces. is there a way to do it ? i created to different properties on my  model folder.
1 - 4 of 41
    Altair Employee
    OP
    Hi francesco aloschi,
    Create different components and move each set of surfaces to specific components and assign properties with desired thickness to it. As described below.
    Thank you
    Altair Employee
    OP
    i don't know wht buy it doesn't work. this was my procedure:
    1)i created two new components
    2) i created two new properties but in property card i don't know how select the right surface (or better the elements in the surface that need to have 2.5 or 3mm thickness)
    so when with f10 i check if i assigned the right thickness it doesn't appear
    Altair Employee
    OP
    You need to move the elements to the new components using Organize panel in the Tool page. Then, you assign respective properties to the new components.
    Thank you
    Altair Employee
    OP
    thank you so much for this help it worked finally
