How to set a port voltage
User: "Liu Xiao"
Altair Community Member
Updated by Liu Xiao
Hello everyone,
Thanks for your interest。
I wanna give one port Time-varying voltage and set other as 0 in schematic.
I'm not sure if I should set it in schematic or use time domain analysis. How can I set parameters for port 1 only if I use time domain analysis in postfeko?
Best regards,
David
1 - 13 of 131
    User: "Torben Voigt"
    Altair Employee
    Updated by Torben Voigt
    Hi David,
    For time-varying signals you should use the Time Analysis in POSTFEKO. There is a simple example in the ExampleGuide, section G.
    Make sure to simulate a fitting frequency range for your time signal. Good videos can be found on YouTube:
    https://www.youtube.com/watch?v=ahb6SCsYhzY
    https://www.youtube.com/watch?v=GSUdAjzwH-o
    Best regards,
    Torben
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Hi David,
    Best regards,
    Torben
    Hi Torben,
    thanks for your reply.
    I have two questions after watching the video.
    1. I have data on the voltage as a function of time for three ports. How do I input the data to a specific port?
    2. I want to achieve the above, should I focus on Time Analysis or schematic?
    Altair Employee
    Hi Torben,
    Hi David,
    The time signal will be applied to the excited ports. So I would suggest to excite Port 1 only.
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Hi David,
    Hi Torben,
    good idea! I will try it. When I do the Time Analysis, btw, will what I set the port value in schematic affect the final result?
    Altair Employee
    Hi Torben,
    No, a simple 1V voltage source should do.
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    It is very helpful for me and I have one more question.
    How can I get result like this?
    I think this should be solved by relying on Time Analysis. image
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Sorry, I didn't make it clear.
    What I mean is that I want to get the output data under a set of signals. The signal is the port voltage based on the time.
    Altair Employee
    Hi @Liu Xiao ,
    Unfortunately, I don't quite understand your question. The image seems to show the E-field over frequency. In POSTFEKO, you can view results over both time and frequency in Time Analysis.
    Best regards,
    Torben
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Hi @Liu Xiao ,
    Best regards,
    Torben
    Hi Torben,
    how can I view the frequency domain result in Time Analysis?
    Best regards,
    Xiao
    Altair Employee
    Hi Torben,
    Best regards,
    Xiao
    Hi @Liu Xiao,
    This picture shows it:
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Hi @Liu Xiao,
    Hi,
    one more question, if I view the result in "trace - near field", will the result be based on Time Analysis?
    There is no difference in my model if I add the time signal or not.
    Altair Employee
    Accepted Answer
    Hi,
    Hi @Liu Xiao,
    Now I know what you're looking for. You can do this with a little workaround:
    • Add your frequency near field result to a Cartesian graph
    • Add you time signal to the same graph and switch the independant axis to "Frequency":
    • Add a new Trace to the graph and multiply the near field and the time signal:
    Hope this helps!
    Best regards,
    Torben
    User: "Liu Xiao"
    OP
    Updated by Liu Xiao
    Hi @Liu Xiao,
    Hope this helps!
    Best regards,
    Torben
    Thank you so much and have a nice weekend!
