How to set a port voltage
Hello everyone,
Thanks for your interest。
I wanna give one port Time-varying voltage and set other as 0 in schematic.
I'm not sure if I should set it in schematic or use time domain analysis. How can I set parameters for port 1 only if I use time domain analysis in postfeko?
Best regards,
David
Best Answer
Liu Xiao said:
one more question, if I view the result in "trace - near field", will the result be based on Time Analysis?
There is no difference in my model if I add the time signal or not.
Hi @Liu Xiao,
Now I know what you're looking for. You can do this with a little workaround:
- Add your frequency near field result to a Cartesian graph
- Add you time signal to the same graph and switch the independant axis to "Frequency":
- Add a new Trace to the graph and multiply the near field and the time signal:
Hope this helps!
Best regards,
Torben1
Hi David,
For time-varying signals you should use the Time Analysis in POSTFEKO. There is a simple example in the ExampleGuide, section G.
Make sure to simulate a fitting frequency range for your time signal. Good videos can be found on YouTube:
https://www.youtube.com/watch?v=ahb6SCsYhzY
https://www.youtube.com/watch?v=GSUdAjzwH-o
Best regards,
Torben0 -
Torben Voigt_20420 said:
Hi David,
Best regards,
TorbenHi Torben,
thanks for your reply.
I have two questions after watching the video.
1. I have data on the voltage as a function of time for three ports. How do I input the data to a specific port?
2. I want to achieve the above, should I focus on Time Analysis or schematic?0 -
Liu Xiao said:
Hi Torben,
2. I want to achieve the above, should I focus on Time Analysis or schematic?Hi David,
The time signal will be applied to the excited ports. So I would suggest to excite Port 1 only.
0 -
Hi David,
Hi Torben,
good idea! I will try it. When I do the Time Analysis, btw, will what I set the port value in schematic affect the final result?
0 -
Liu Xiao said:
Hi Torben,
No, a simple 1V voltage source should do.
0 -
It is very helpful for me and I have one more question.
How can I get result like this?
I think this should be solved by relying on Time Analysis.
0 -
Sorry, I didn't make it clear.
What I mean is that I want to get the output data under a set of signals. The signal is the port voltage based on the time.
0 -
Hi @Liu Xiao ,
Unfortunately, I don't quite understand your question. The image seems to show the E-field over frequency. In POSTFEKO, you can view results over both time and frequency in Time Analysis.
Best regards,
Torben0 -
Hi @Liu Xiao ,
Best regards,
TorbenHi Torben,
how can I view the frequency domain result in Time Analysis?
Best regards,
Xiao
0 -
Hi @Liu Xiao,
This picture shows it:
0 -
Liu Xiao said:
Hi @Liu Xiao,
Hope this helps!
Best regards,
Torben1 -
Hi @Liu Xiao,
Hope this helps!
Best regards,
TorbenThank you so much and have a nice weekend!
