1D element fracture
MNajeeb
MNajeeb Altair Community Member
edited October 2020 in Community Q&A
Hello
Is it possible to model a 1D element that fails in either tension or shear? I would like analyze a breakaway feature on a structure that absorbs a portion of the impact energy and breaks off.
Fracture can be either in tension (i.e cable) or in shear (i.e shear pin).
Thank you
Answers
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited July 2019
    Hi,
    most spring properties support some failure criteria. Spring beam supports deformation, force and energy-based failure criteria.
  • MNajeeb
    edited July 2019
    Thanks! I will try using P4_Spring properties with the delta_max defined.
Welcome!
Welcome!
