compliance is negative or large
Hi all,
I had given run in optistruct for linear static analysis
but it shows like this -
*** WARNING # 312
In static load case 10
the compliance is negative or large 1.389270E+08
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
wat is this mean????
wat is compliance???
Can anyone pls help me??/:-({|=
Thanks&Regards
Sai
1 - 5 of
51
Hi,
If you run analysis only, turn 'run options' to 'analysis'. You seem to set inconsistent material parameters, please check again if young modulus is too small
