🎉Community Raffle - Win $25
Join and Win
set the variable from F10 (Quality Check panel)
Hi,
  I want set the three variable whenever I use F10 Quality check.
For example,
*elementtestinterangle elements 1 30 1 2 1 4 0 "  3D Tria Face Min Angle  "
The above command is to check min angle of 3d face tria,
Inthese I need to get {internalangle,30,3D Tria Face Min Angle} and set to a variable.
Also if,
*elementtestlength elements 1 1.3 2 1 2 0 "  2D Length <  "
the above command is executed
I need to get {length,1.3,2D Length <}
Respectively,
1 - 3 of 31
    I'm sorry. I was not so clear to me. Can you elaborate a little bit more the big picture?
    What are you trying to accomplish here?
    Do you want to do a check in the GUI and have it writting something for you? I didn't get it, sorry.
    tinhUser: "tinh"
    Altair Community Member
    Accepted Answer
    Updated by tinh
    Hi
    Assume that you want:
        whenever you press F10 and click "length <" and "min angle <", you want to store some things that describe your actions.
    Let's hook to *commands:
    ::hwt::AddCallback *elementtestinterangle p_RecordCheckActions leave  ::hwt::AddCallback *elementtestlength p_RecordCheckActions leave  proc ::p_RecordCheckActions args {       regsub -all {[\{\(\,\*\)\}]+|elementtest} $args " " tcl_cmd      lassign $tcl_cmd param -> -> threshold      set type [lindex $tcl_cmd end]       puts "set your_variable {$param, $threshold, $type}"       list $param $threshold $type  }
    Tested on HM2019 Classic
    Hi
     Hi Tinh,
      This is exactly what I want, Thank you.
