🎉Community Raffle - Win $25
Join and Win
Associate 2D mesh with surface
User: "mvass"
Altair Community Member
Updated by mvass
Hello.
Maybe a trivial question here, but when a 2D mesh is created on a surface and for some reason a translation of both the surface and the mesh is performed, the association between them is lost (naturally) and then the process of selecting elements or nodes on that particular surface becomes laborious. As far as I know, one can go to Geometry-->Node edit and then select 'Associate' to fix this, but only one surface, one line etc. can be selected, making the process hard, or impossible when large meshes have to be processed. Any ideas on how to perform the association faster?
Thank you.
