SAS JSON libname engine support
Executing on Altair SLC 2023 - Community Edition (05.23.01.00.000106), trying to use the JSON libname engine in SAS.
I get an error. Is this engine not supported? Are there plans to support?
4 libname xxx '/altair/dataset-json'; /* SAS library */
NOTE: Library xxx assigned as follows:
Engine: WPD
Physical Name: C:\altair\dataset-json
5 libname ex32 json '/altair/dataset-json/json_out/adam\adtte.json'
ERROR: * Line 1, Column 32758
Syntax error: value, object or array expected.
6 map='user32.map' automap=create ordinalcount=all; /* JSON file */
7 proc copy in=ex32 out=xxx;
ERROR: Library "ex32" cannot be found
NOTE: Procedure COPY was not executed because of errors detected
8 run;
