SAS JSON libname engine support
Executing on Altair SLC 2023 - Community Edition (05.23.01.00.000106), trying to use the JSON libname engine in SAS.
I get an error. Is this engine not supported? Are there plans to support?
4 libname xxx '/altair/dataset-json'; /* SAS library */
NOTE: Library xxx assigned as follows:
Engine: WPD
Physical Name: C:\altair\dataset-json
5 libname ex32 json '/altair/dataset-json/json_out/adam\adtte.json'
ERROR: * Line 1, Column 32758
Syntax error: value, object or array expected.
6 map='user32.map' automap=create ordinalcount=all; /* JSON file */
7 proc copy in=ex32 out=xxx;
ERROR: Library "ex32" cannot be found
NOTE: Procedure COPY was not executed because of errors detected
8 run;
Hi Lex,
What happens if you put LIBNAME EX32 above LIBNAME XXX, and are more explicit about your locations by prefixing them with 'C:'?
The default folder can't be changed in the Workbench and defaults to your current Workbench folder.
............Phil
Hi Lex,
............Phil
Thanks, Phil.
No that is not the issue. I found the issue. See my other response.
Lex
Hi Lex,
You should find that PROC JSON and LIBNAME JSON are both working in WPS/SLC 5.23.1.
The error message you are seeing "value, object or array expected" says that the format of the JSON file does not meet the requirements for being read by our LIBNAME JSON engine. Are you able to show us some of the top level structure of this JSON file? Does the opening line begin with "{" left brace character for example?
Best Regards,
Nico
Hi Nico,
Thanks! I found the issue.
The JSON file is valid (see: https://github.com/lexjansen/dataset-json-sas/blob/master/json/adam/adtte.json).
I did not see earlier that the code actually continues after the error, and does create the datasets.
The error seems to happen because the JSON file is just one long record.
When I format and indent the JSON file, I do not get the issue.
I think this should be considered a bug.
Thanks again!
Best,
Lex
Thanks Lex. I'll raise a bug report with our developers and let you know how it is received.
Best Regards,
Nico
Hi Lex,
The original JSON file is a single line with 56694 chars. With shorter JSON examples consisting of one long line, I can get SLC to read it in by setting LRECL=32767. However we can't set LRECL to 56694.
So, it appears that SLC's JSON engine is limited by LRECL line length, and you were able to read your JSON file by reformatting it and thereby ensuring that no lines were longer than LRECL.
Best Regards,
Nico
Hi Nico.
Reformatting is not a solution, especially now that the FDA is starting a Dataset-JSON pilot, and they have indicated that file sizes are an issue. So, we need to make the JSON files as small as possible, by using the NOPRETTY option on PROC JSON.
Thanks, Lex
Hi Lex,
I hope you're doing well!
I wanted to let you know that in our more recent SLC maintenance versions, we've made improvements that allow you to set a higher value for the LRECL
option. This must be specified in the filename
statement when working with files.
Here's a sample for your reference:
filename tx disk "C:\temp\pretty.json" lrecl=1073741823;
libname bean JSON fileref=tx;
proc contents data=bean._all_;
run;
proc datasets lib=bean;
quit;
Regards
Lorenz
Here is some feedback from trying out JSON libname. The record length limitations seems solved. That's great!
I tried the following:
filename tx disk "C:\_github\lexjansen\dataset-json-sas\json\sdtm\dm.json" lrecl=1073741823; libname bean JSON fileref=tx; proc contents data=bean._all_; run; proc datasets lib=bean; quit; proc copy in=bean out=work; run;
The JSON file can be found at:
https://github.com/lexjansen/dataset-json-sas/blob/master/json/sdtm/dm.json
115 proc copy in=bean out=work; 116 run; NOTE: Copying Member "BEAN.root" to WORK.root (memtype=DATA) WARNING: Copy is overwriting existing dataset WORK.root NOTE: 1 observations read from input dataset BEAN.root NOTE: Output dataset WORK.root has 1 observations and 14 variables NOTE: Member "BEAN.root.DATA" (memtype=DATA) copied NOTE: Copying Member "BEAN.columns" to WORK.columns (memtype=DATA) WARNING: Copy is overwriting existing dataset WORK.columns NOTE: 27 observations read from input dataset BEAN.columns NOTE: Output dataset WORK.columns has 27 observations and 8 variables NOTE: Member "BEAN.columns.DATA" (memtype=DATA) copied NOTE: Copying Member "BEAN.rows" to WORK.rows (memtype=DATA) WARNING: Copy is overwriting existing dataset WORK.rows NOTE: 0 observations read from input dataset BEAN.rows NOTE: Output dataset WORK.rows has 0 observations and 29 variables NOTE: Member "BEAN.rows.DATA" (memtype=DATA) copied NOTE: Copying Member "BEAN.sourceSystem" to WORK.sourceSystem (memtype=DATA) WARNING: Copy is overwriting existing dataset WORK.sourceSystem NOTE: 1 observations read from input dataset BEAN.sourceSystem NOTE: Output dataset WORK.sourceSystem has 1 observations and 4 variables NOTE: Member "BEAN.sourceSystem.DATA" (memtype=DATA) copied NOTE: Copying Member "BEAN.alldata" to WORK.alldata (memtype=DATA) WARNING: Copy is overwriting existing dataset WORK.alldata NOTE: 648 observations read from input dataset BEAN.alldata NOTE: Output dataset WORK.alldata has 648 observations and 6 variables NOTE: Member "BEAN.alldata.DATA" (memtype=DATA) copied NOTE: 5 members copied NOTE: Procedure copy step took : real time : 0.030 cpu time : 0.031
I was expecting the WORK.rows dataset to have 18 observations, as I get with SAS, but it has 0 observations.
Below is the SAS log.
Also, the WORK.ALLDATA dataset is structured quite different from SAS, although it does seem to have all data.
10 proc copy in=bean out=work; 11 run; NOTE: Copying BEAN.ALLDATA to WORK.ALLDATA (memtype=DATA). NOTE: BUFSIZE is not cloned when copying across different engines. System Option for BUFSIZE was used. INFO: Data set block I/O cannot be used because: INFO: - The data sets use different engines, have different variables or have attributes that may differ. NOTE: There were 674 observations read from the data set BEAN.ALLDATA. NOTE: The data set WORK.ALLDATA has 674 observations and 5 variables. NOTE: Copying BEAN.COLUMNS to WORK.COLUMNS (memtype=DATA). NOTE: BUFSIZE is not cloned when copying across different engines. System Option for BUFSIZE was used. INFO: Data set block I/O cannot be used because: INFO: - The data sets use different engines, have different variables or have attributes that may differ. NOTE: There were 27 observations read from the data set BEAN.COLUMNS. NOTE: The data set WORK.COLUMNS has 27 observations and 8 variables. NOTE: Copying BEAN.ROOT to WORK.ROOT (memtype=DATA). NOTE: BUFSIZE is not cloned when copying across different engines. System Option for BUFSIZE was used. INFO: Data set block I/O cannot be used because: INFO: - The data sets use different engines, have different variables or have attributes that may differ. NOTE: There were 1 observations read from the data set BEAN.ROOT. NOTE: The data set WORK.ROOT has 1 observations and 14 variables. NOTE: Copying BEAN.ROWS to WORK.ROWS (memtype=DATA). NOTE: BUFSIZE is not cloned when copying across different engines. System Option for BUFSIZE was used. INFO: Data set block I/O cannot be used because: INFO: - The data sets use different engines, have different variables or have attributes that may differ. NOTE: There were 18 observations read from the data set BEAN.ROWS. NOTE: The data set WORK.ROWS has 18 observations and 29 variables. NOTE: Copying BEAN.SOURCESYSTEM to WORK.SOURCESYSTEM (memtype=DATA). NOTE: BUFSIZE is not cloned when copying across different engines. System Option for BUFSIZE was used. INFO: Data set block I/O cannot be used because: INFO: - The data sets use different engines, have different variables or have attributes that may differ. NOTE: There were 1 observations read from the data set BEAN.SOURCESYSTEM. NOTE: The data set WORK.SOURCESYSTEM has 1 observations and 4 variables. NOTE: PROCEDURE COPY used (Total process time): real time 0.05 seconds cpu time 0.01 seconds
Here are some examples most use sas, but many use R and Python and may run in the personal SLC.
Select json from d:/git/git_010_repos.sasbdat
REPO
https://github.com/rogerjdeangelis/utl-accessing-specific-value-from-JSON-file
https://github.com/rogerjdeangelis/utl-converting-a-simple-nested-json-file-to-a-sas-dataset
https://github.com/rogerjdeangelis/utl-converting-a-two-deep-nested-json-file-to-retangular-sas-tables
https://github.com/rogerjdeangelis/utl-create-a-specific-json-list-structure-from-R-lists
https://github.com/rogerjdeangelis/utl-creating-a-sas-table-from-a-json-file-using-r-and-sas
https://github.com/rogerjdeangelis/utl-creating-a-sas-table-from-a-json-file-using-r-jsonlite-and-sas
https://github.com/rogerjdeangelis/utl-export-jsonlines-newline-delimited-json-records-streamout
https://github.com/rogerjdeangelis/utl-extracting-data-from-a-json-file-from-api-using-r-lists
https://github.com/rogerjdeangelis/utl-import-a-json-file-with-three-deep-nesting
https://github.com/rogerjdeangelis/utl-import-dbf-dif-ods-xlsx-spss-json-stata-csv-html-xml-tsv-files-without-sas-access-products
https://github.com/rogerjdeangelis/utl-import-json-file-and-export-to-sas-with-long-variable-names
https://github.com/rogerjdeangelis/utl-importing-a-four-deep-nested-JSON-file-into-SAS-using-R
https://github.com/rogerjdeangelis/utl-importing-simple-json-a-comparison-of-R-and-SAS
https://github.com/rogerjdeangelis/utl-parsing-a-simple-json-file-in-r-and-sas
https://github.com/rogerjdeangelis/utl-parsing-json-strings-longer-than_32k-bytes-R-and-SAS
https://github.com/rogerjdeangelis/utl-proper-handling-of-nulls-when-creating-json-output-to-load-into-databases
https://github.com/rogerjdeangelis/utl-simple-json-file-to-sas-table-using-sas-and-r
https://github.com/rogerjdeangelis/utl-very-simple-json-file-to-sas-table-using-r-and-sas
https://github.com/rogerjdeangelis/utl_SAS_dataset_to_json_using_SAS_R_Python_and_WPS
https://github.com/rogerjdeangelis/utl_converting_simple_json_file_to_a_sas_table
https://github.com/rogerjdeangelis/utl_converting_simple_json_file_to_a_sas_table2
https://github.com/rogerjdeangelis/utl_converting_very_simple_json_file_to_a_sas_dataset
https://github.com/rogerjdeangelis/utl_create_database_table_from_complex_json_file
https://github.com/rogerjdeangelis/utl_creating_sas_wps_datasets_from_complex_ill_formed_json_files
https://github.com/rogerjdeangelis/utl_how_to_stream_stacked_multiple_json_files_into_sas_dataset
https://github.com/rogerjdeangelis/utl_import_json_r_2_lines_of_code
https://github.com/rogerjdeangelis/utl_importing_json_file_data_into_sas_as_a_dataset
https://github.com/rogerjdeangelis/utl_parsing_a_complex_nested_json_file_using_r_lists
Hi Lex,
Best Regards,
Nico
