Not mappable solids
Hello, i Have problem with not mappable bar element
I tried to toggle showen edge to match mesh for hole, but after this operation solid became not mappable even if i mesh a surface. Screens are updated below.
What should I do?
1 - 4 of
41
You should do meshing manually, to use automesh on mappable solids we have to modify geometry (it is ok with simple geometry)
and time to modify geom is as long as make mesh manually (drag, linear 3d,...)
