Hello,
So I imported a semi-circle geometry from SolidWorks (IGES format) into HyperMesh and ive been trying to carry out topology optimisation on the piece. However, I keep getting the Error code: 2372. I've researched online that it may be PSHELL elements that haven't been deleted but how do I delete these without deleting the mesh?
Does it have something to do with the thick line that can be seen in the image or maybe its that node that I can't remove (highlighted by the green ring) [Please look at the image attached]
I've been struggling on this for hours, can someone please help?
